hi i have installed desktop console software on one of the PC i couldnt connect to the appliance server through the solar winds desktop console, but i can ping to that server from the cmd??????.... any help???????????????
To get you in brief..
i have installed VMware vshpere client 5 and solar wind manager onto a server
Then i have installed the desktop console software on one of the pc .. the server and the pc are on same network i can ping the server from pc .. when try to connect same thing from solar winds LEM its asking for password which i have not set any ... ... and then it say couldnt connect the virtual appliance??
any help bit urgent ????
Hi, there.
So, if I understand your most recent post, you're just having issues with your desktop console password? If that's the case, use username "admin" with password "password" -- those are the default credentials per http://www.solarwinds.com/documentation/LEM/Docs/SolarWinds-LEM-QuickStartGuide.pdf. (The default credentials are the same for the desktop and web consoles.)
Let me know if you have some other issue.
Phil
Hi Phil,
thanks for replying
i'll explain you in bit in brief??
i have installed this desktop console software on this once , as soon as i start the software.. it prompted me to enter the IP address.. so i have given it the IP address of the server where the vmware and solar winds software is installed.. it asked me for password ?? which ive tried all those .. even admin and password ..
No joy ...
Ah...when it asks for the IP address, it's asking for the IP address for the LEM appliance, not the VM server it's installed on. To see the IP address for the LEM appliance, log onto your VMware client, and then look at the "console" view for the LEM VM. You should see a blue screen that notes the LEM IP address.
Hi Phil3
Thanks for replying
The LEM console (Blue Screen) says NO IP address is assigned .. i have restarted the VM guest ... no joy .. do i need to assigned the IP address in the same subnet ???
any idea??
I have assigned the Static IP address in the console
When i've entered the IP address into the web browser .. i can see the login page but the default username and the password is not working (admin and password)...?????
any helpppp
Looks like our PM answered you here: http://thwack.solarwinds.com/message/176138#176138. Did resetting the admin password work for you?
