Hello Thwack;
Has anyone been successful in importing IP addresses from Toolset's IP address Management app into IPAM?
Regards
Just closing the loop on this issue.
Yes, this is possible.
The steps can be found here.
www.solarwinds.com/.../OrionIPAMAGImportingIPAddressesSettings.htm
Hello Mark;
These instructions are only for importing from a Excel xls or csv file. That would mean exporting each of the IP addresses ranges. Isn't there a way to import the whole ipdb file into IPAM?
i too found no way to do this and have been entering all of mine manually
There is a command line utility you can run to import subnets and IP's from Toolset, let me get the directions for you and re-post
Here you go
The parameter after STOP and START need to be enclosed within double quotes (and not the ones Word replaces on you with).
1. Locate the Toolset IP Address Manager database on your Toolset server.
Note: The Toolset IP Address Manager database has an .ipdb extension.
2. Copy the Toolset IP Address Manager database to an appropriate location on your Orion server.
3. Open the Command Prompt on your Orion server.
Note:Typically, the command prompt may be opened by clicking Start > All Programs > Accessories > Command Prompt.
4. Enter CD <volume>:\Program Files\SolarWinds\Orion\IPAM.
5. Enter NET STOP "SolarWinds IPAM Information Service"
6. Enter SolarWinds.IPAM.Init.exe -import <Full path to your Toolset IP Address Manager database>.
7. Enter NET START "SolarWinds IPAM Information Service"
We have already populated IPAM with all our supernets and some subnets. If we import our Toolset IPDB will IPAM insert each subnet under the corresponding supernet? What happens if IPAM encounters a duplicate subnet on import?
rgward,
That's an excellent point you bring up. I'm glad you asked.
The import tool was meant to help initialize the install. It will seek out an existing subnet of the same address space and overwrite its contents. I wouldn't recommend you run it since all your subnets have been added... leading to a potential reversion of changes.
New subnets are added under "IP Networks"... the top level group.
Thanks Peter for your quick reply! Okay, this will work for us, I think. We're not doing any polling of subnet address spaces yet. So, with the Toolset subnets imported at the top level, we should be able to drag and drop them into the proper supernet.
I am not sure if this step was suppose to be verbatim but didn't work for me:
5. Enter NET STOP SolarWinds IPAM Information Service.
I used: net stop swipaminformationservice
After figuring that out, the import failed for me so I will be contacting support on it.
Can you post the error you are getting?
Sure, it was:
Unhandled Exception: System.OverflowException: Failed to convert parameter value from a UInt64 to a Int64. ---> System.OverflowException: Value was either too large or too small for an Int64.
I just got off the phone with tech support and they had a hotfix for it and the import worked great afterwards.
