I can not create an advanced alert when using two custom puller
For example
This configuration is not work ((((
If I do a 'Trigger Alert' with only one from every pollers - 'Trigger Alert' worked properly
Your alert is based on all the conditions being true, which therefore includes the test (Poller Name == x) AND (Poller Name ==y) in there.
Is that correct, or do you actually mean (Poller Name == x) OR (Poller Name ==y)?
If you want the test for either of the poller names, you will need to add a new Condition Group which is set to "any of the following" and then put your 2 Poller Name tests under that Condition Group.
Thanks for the helpYes, I want to use two poller
Use two poller on trigger conditions - it was just an example/test
That is if I add a secondary poller, then 'trigger alert' does not work
I tried using Condition Group - the same result - does not work (((Give me please example of Condition Group and I'll check and let you know the resultI want to use 'all' the conditions
Node status UpPoller name is equal BGP Peer Statefield Row ID contains 10.0.%.1field Status equal 6andPoller name is equal BGP Local Addressfield Row ID contains 10.0.%.2
You can use an all and any (and and ors)
That is "Alert if NameName like (*Bob* or *Carl*) and Poller Name like (*bgp* or *eigrp*)"
Thank youBut I need to use the condition "and" not "or"Poller BGP-x AND(&) BGP-y
But one poller will never have two names, so it will never alert... I think there is a little confusion over how alerts work. Based on your original screen shot, you want to trigger the alert when: Node name is like *RTR....* and that node is up and the poller's name is like both *bgp peer state* and *bgp peer local address* - but nothing about the content of those pollers.
Can you explain what you are actually looking for in plain not techy language? I bet once we establish that, we can get you going and you'll see why an or might do what you need.
Hi
Sorry my bad english (((
I need have alert if:
node is UP
For defined Poller, "BGP status" for the neighbor 10.0.%.1 status equal 6
and
For defined Poller "Local BGP Address" for the local address 10.0.% .2 status is not equal 0
Hmm, I think I get it now, you want the alert to be based off two different poller values. That is not how the alert engine works , it only focuses on one poller at a time and you can't compare two values at the same time in one trigger. I do understand there is a value to it and I have seen others trying to do that, but I don't know if or how they got it working.
You might need to either do a custom SQL alert or an alert with a suppression (suppression is strange, so this might not work as well as one could hope for)
The suppression is backwards from what you said, but a suppression is saying don't alert if this condition exists anywhere in the database (that's the only way I could think of comparing the data in two pollers).
Thank you
It turns out that we can not use two or more Pollers
