I just noticed that I don't see a Windows service for IPSLA...like NTA, etc. EOC is showing it down on 1 server but I'm on that server and the IPSLA graphs are working, etc.
BB
Nope, take a look at the VoIP Collector service resource on the actual Orion web site.
There isn't a service just for IP SLA. IP SLA utilizes the Orion Module Engine and Job Scheduler services.
Is this a new stance from SW now? I mean NTA has it's own service, Voip Monitor had the same. EOC is reporting the IPLSA manager down on one of rmy servers and it's not. I'm not sure what to restart to fix that.
Is the service that EOC is reporting as down, the one running on your main Orion poller?
Did you have at one point additional VoIP Monitor installations when you installed IP SLA Manager?
We have 4 Orion servers. 1 runs the old VoIP Monitor because it's running V9.1. The Other Orion server, showing down, is IPSLA Manager on a 9.5.1 server.
These were both showing "up" last week.
Take a look at the Orion VoIP Collector Services resource. It should have a column "Last Registered Time" That time should be close to current time.
If it is more than 15 minutes old, then the there is an issue with your VoIP/IP SLA issue.
If it is recent, then EOC is probably misinterpreting that value.
From EOC? I don't see that column.
I checked the Orion server and the service is running and the time stamp is up to date. I'll open a ticket on EOC.
