I don't know if this is an Orion or NTA problem - see attached screenshot.
I get a bar in the middle of the screen in Firefox and IE7.
What version are you using? NPM 8.1? or NPM 9.0 SP1? There is no 9.1 yet.
<slaps forehead> So it does. Which version of Firefox?
Sorry about the Orion version.
Firefox version is 2.0.0.16
Works in IE6.
Can you give us more background on the problem? Was it something that occured when you installed SP1?
Edit \Inetpub\Solarwinds\Orion\TrafficAnalysis\Admin\AllNetflowSourcesEdit.aspx. Find this code around line 173:
<FooterTemplate> </div></FooterTemplate>
And delete those three lines.
