We have an old Polling Engine we're no longer using. How do I remove it from the database?
Best bet might be just to open a support case
Start\Prog\Solarwinds Orion\Monitor polling engines. Servers, Monitor polling engines.
This should pop up a node management page where you can change pollers from one database to another, but also offer an option to delete the empty poller if you are no longer using it.
"Polling Engines\Delete unused polling engines"
Fantastic! Thanks!
I'm not seeing these options under "Servers" -- Just Stop/Start services, Configure Hot Standby, Poller Loadbalancing.
9.5slx.
I'm not seeing these options under "Servers" -- Just Stop/Start services, Configure Hot Standby, Poller Loadbalancing.9.5slx.???
It's under poller Load Balancing
No it's not under poller Load Balancing. I have a non-existant polling engine I'm trying to remove and I see no way of doing it!
Hi
Had the same issue the poller was not in the list of pollers, but when I closed the load balancing window it then asked me if I wanted delete a polling engine as it had no elements assigned, so I said yes and then it was removed
Hope that helps
James
you have to get everything off the old poller before it will let you delete it.
