Where do you download the latest version and how do you update it?
There is a readme in the zip file for the MIB DB you download, but here is the content:
You should be able to download from the customer portal and send a request to support to update
That's what I'm trying to ask. how and where do I find the customer portal to download the information and once I get it downloaded, how do I load it into Orion.
Customer portal is here. Once you login with your SWID you would see the link on the left.
Once I get it downloaded, what do I do with it?
PERFECT! Thanks for the quick replies. As you might have surmised, I'm an Orion noob so you will probably be hearing from me a gain.
Thanks again!
No worries, that is what the forum is here for!
