I am new to LEM and am curious if it's possible to create your own reports in the reporting applicaiton that comes with LEM and if so, how?
Thanks in advance for any help with this.
You CAN customize existing reports with a filter (for example, take the Authentication Report and make it an "Administrators Authentication Report"). Run report, add criteria with Select Expert, Export to RPT, and run the RPT with the embedded criteria.
Instructions: SolarWinds Knowledge Base :: Creating a Custom Filtered Report
We don't provide a custom report builder (from scratch) yet. You can, if you are adventurous, use Crystal Reports to create entirely new ones. I don't have a quick KB, but we might have a doc we can provide.
Thanks, this is exactly what I was hoping for!
A work around that I use is to create nDepth queries and save them. Then you can run and export to .pdf when you need it. The only problem being you can't run them on a scheduled automatic basis.
Hope this helps.
Chrystal Taylor
http://www.loop1systems.com
That is a really good suggestion, I will definitely give that a try as well, thanks!
Ok, so a follow-up question... if I save over one of the default layouts, how do I restore the original?
For reports, it's just re-copying the file from a stock install (if you need it, I can attach).
For nDepth searches, a little more complicated, but we could give you the search and you could save a new one (or log in as a different user to get the stock search, copy and paste using the "text mode" search toggle).
It's the nDepth Export layout that I managed to save over. I understand that I can just re-create a layout but I would like to know how to restore one if possible.
OH, the layout, <light bulb>
Export layouts are one of those little things that doesn't have an Import/Export. With the AIR console, we can restore defaults a little easier, since they are files on disk on your system. With the web console, though, it's a matter of files on disk on the appliance.
So, it looks like:
