We just upgraded to 10.4.2. The interface graphs show the traffic in the chart as mbps but the label on the side shows BYTES. is there a way to correct this?
Hi rob_ib,
would it be possible to see screenshot of those graphs? It would help us to investigate the issue a bit.
Pavel
Label BYTES PER SECOND is not computed from data as for example 400.00 Mbps, but it is statically defined for given chart and his purpose is just inform you what values on y-axis represents.
this is by design. We are not able to change the label according units shown on the graph. It would be impossible to have this dynamical and follow units on the graph.
But it is wrong. It should be bits per second or do not have anything there.
I had a case opened for this issue in March ,case number 454062.. According to Sw support this will be fixed in the next maintenance release. The parent FB case is number 197460.
Rick
Yep, Rick is right. I can confirm it was already reported and it is fixed in next release which should be out soon. Stay tuned
Thanks for posting on thwack!
I reported this over a year ago and was told this would be fixed in the next release... ;-)
This was back when the graph was still "old-style".
