Does the Real-Time NetFlow Analyzer have support for any flow sampling other than NetFlow? ie. sFlow, JFlow, etc?
Found this thread:
Mark Wiggans said 2.5 years ago that it is possible in a future release, but......
It does support sflow
Well, then I seem to be having an issue. haha I have setup an Extreme switch to export flow data to an workstation, the Real-Time tool is up, I have added the switch, I see the interfaces and I see traffic stats in the list for the interface I want to watch. When I click Start Flow Capture I get an error stating that NetFlow is not detected on the selected interface. Wireshark confirms I have the sFlow packets coming to this workstation.
It's got to be sflow v5
Packet info from WireShark shows v5...
Hi There---
Have you looked at the KB article that addresses flow template fields required for NTA? Take a look and see if that helps. If not, I'd open a support ticket on this.
M
Hi Marie, from the Notes of the KB:
When SolarWinds states that a device is supported by Orion NTA,SolarWinds has determined that at least one of the templates the deviceis capable of exporting will satisfy the Orion NTA requirements.
I've looked and can't find the list. All I can find is the list of Multi-Vendor Support (extreme being one of them).
Hey Aaron--
Let me check on this and get back to you. Sorry for the delay.
Hi Marie, just curious if you were able to find out any info on this for me? I have still not had any luck getting the Real-time tool to work with these Extreme switches. I will be opening a trouble ticket.
Aaron
