Has Compellent been added to the roadmap of supported vendors for Storage Profiler?
It is on our roadmap as a high priority, will update the What we are working on post as soon as I can tell you more.
If you want to be a beta or RC tester, please let me know.
Brian
Yes, it is on the list.
Brian,
Is there any movement on this. We are taking delivery of our first Compellent array. As we slowly continue to migrate away from EMC, it would be nice to know if Solarwinds can be our SAN monitoring solution or if we need to look elsewhere - when the time comes to pull the trigger. Thanks!
John
Can anyone @ SW comment on the status of this? Thanks!
We are a Compellent shop and having pretty major performance issues with our VMs which I believe I have tracked down to the Data Progression feature not doing its job. I would like to be a beta tester. We already have Virtualization Manager and I hope to beta test 5.0 of that as well with the addition of Hyper-V support.
Raylgood - curious as to your compellent issues as we are moving to the platform and are about to migrate our vm's onto it. Anything you can share?
Sorry this took so long. We did finally figure out the problem. For some reason the company that implemented this for us did not set up Replay on our LUNs. This is crucial for data progression to work. Once we did this data began to move where it needed to be. We also added some more disks to our Tier1 and changed to RAID 5-9 for Tier 3. Things are working much better now.
