BUMP...
I would like to know the answer to this as well. Is there any benefit to having multiple CPU's (physical or logical) for the polling process? My polling engines are currently on servers with single CPU's, but I'm curious if anyone has any insight into whether the process can multithread, and whether there's any significant benefit to having additional CPU's.
Specifically, I'm curious about 8.5. If multithreading is not available today, is it something that's being considered?
The SNMP poller is not multi-threaded, so multiple CPUs won't directly impact performance. To the extent that there are other processes sharing resources on the Orion server, however, there would be indirect benefits.
As to the future, if we were to re-write the poller, we would almost certainly make it multi-threaded. Do you want this so that you could get more polls out of given poller?
If I say "yes", does that mean you'll be more hesitant to do it, since you won't sell as many polling engine licenses? Just kidding... Kinda...
As it is today, with SLX, the limiting factor is the ability of a single CPU to handle the number of devices that are assigned to that particular system. It's nice not having a device limit to worry about, but my fear is that if you go the route of rewriting the poller to take advantage of additional server resources, that you might decide to do away with SLX and license all Orion pollers based on the number of elements. I guess I can't blame you if you did, but I'll whine and pout about it for a while.
Actually, for our particular case, it probably costs us more money in internal costs to manage and maintain multiple servers than it would if you were to charge more for a single great big honkin' polling server (or at least fewer of them). Of course, it is nice to have the ability to reassign devices among the polling engines for maintenance purposes, and this might be hindered if the licensing model changed.
Whatever you decide... Be gentle...
I was really trying to probe to see if there's some other less obvious advantage to multi-threading. As for what it would mean for licensing, etc., if we did so, I wouldn't worry about it much. There's no certainty that making the poller multi-threaded would really change the reach of an SLX since we'd probably ask that poller to do more anyway.
I would have to say definitely yes. The biggest problem we have with Orion SLX version is how slow it appears to run even though the server still has plenty of resources. I would like to have better performance out of the hardware I have rather than have to go out and purchase more hardware, something I'm sure everyone would want.
Any new info on this? This is a limiting factor for me right now.
This isn't going to change in 2008. What's the limitation?
I'm working on getting Netflow integrated into an existing SLX setup on a dual processor machine. We're looking into upgrading the hardware, but if we can't guarantee that there'll be a significant performance gain, it'll be hard to justify. But between this and the issues I'm having with Netflow, I'm not sure I'll get a sign off on the hardware.
justinh,
NetFlow and other newer modules (APM, VoIP) are multi-threaded and will take advantage of more cores/processors. The thing that is limited to a single thread/single core is the standard Orion poller. This is responsible for polling node and interface status and statistics.
Typically where we see NetFlow impacting Orion is on single processor systems or when the database has I/O issues (for instance if the database server is using RAID 5).
Thanks for the response. I'm on a two CPU machine with 4 GB of RAM. I guess I'll wait for a response to my open ticket. Support has had my diagnostics for almost a week now. Hopefully they'll get back to me soon.
Edit: I don't think we're raiding our SQL. I'll have to ask my db admin what he did with those machines.
