How can I change the display preferences for syslog in NPM?
I want to add a nodename or sysname column and change the default number of messages from 250 to 500.
1. Click Start > All Programs > SolarWinds Orion > Syslog Viewer.
Yes, that works perfectly for viewing the syslog messages on the server.
I think I asked the wrong question. I need to change the syslog display preferences in Orion Web Console.
Prior to the upgrade to 8.1 changes to syslog view in NPM would be reflected in the Web Console.
Now the changes are not being translated. Any ideas?
I don't think adding columns in Syslog Viewer ever had any impact on the web console. I'm looking at 8.1 right now, and I can't duplicate that. Can you recall the steps you took to adjust the columns on the web console?
My 'old' version is 7.8
Any further suggestions guys?
I miss having both the IP and hostname listed in the web console syslog viewer. The web version is so much nicer to search than the viewer on the server.
Yeap. It worked in 7.8.5, but not in 8.5.1. I posed this as a question in one of my cases as well.
