I currently have an alert for HDD space, i would like to round this off to 2 decimal places:
So currently i have:
***WARNING*** Volume ${SQL:Select Substring('${Caption}',1,3) AS Caption} on ${NodeName} is almost full and has ${SQL:Select ${VolumeSpaceAvailable}/ 1024 / 1024 / 1024} GB remaining
Thank you.
Try this:
***WARNING*** Volume ${SQL:Select Substring('${Caption}',1,3) AS Caption} on ${NodeName} is almost full and has ${SQL:Select round((VolumeSpaceAvailable / 1024 / 1024 / 1024),1) from Volumes WHERE VolumeID='${VolumeID}'} GB
HTHStuart
[edit: I just realised that this only does a drive letter substring, not available disk space. I've always found this to be perfectly fine for my uses though - it always looks aesthetically okay.]
I use this as the subject of disk space alert emails:
*** WARNING: ${NodeName} ${SQL:Select Substring ('${Caption}',1,2) AS Caption} Free Space ${VolumeSpaceAvailable} [min=${Minimum_Free_MB}MB]
I have Minimum_Free_MB as a custom property to specify a mimimum amount of free space for specific volumes, and have two alerts - one is a custom SQL alert to do the bytes-to-MB comparison when the Minimum_Free_MB field is not empty. The other alert just checks that the Minimum_Free_MB field is blank and triggers if there's less than 5GB free.
Thank you for your reply.
Im new to NPN and SQL so finding it rather tough, Is there no way to just add something like a =round somewhere to round it off?
also
'${Caption}',1,2)
What does the ,1,2 signify ?
Thank you
try searching google or something formssql round transact-sql
and select the one from msdn.microsoft.com
my bad, you actually want decimal. check here:http://msdn.microsoft.com/en-us/library/ms187746.aspx
decimal[p,s] - the s is what you need to = 2
As a bonus extra, heres what I use for the alert mail:
Alert: ${FullName} is ${SQL:Select Round ('${VolumePercentUsed}',0) from Volumes WHERE VolumeID='${VolumeID}'} Percent UtilizedVolume Size ${SQL:Select round((VolumeSize / 1024 / 1024 / 1024),1) from Volumes WHERE VolumeID='${VolumeID}'} GBCurrently Used ${SQL:Select round((VolumeSpaceUsed / 1024 / 1024 / 1024),1) from Volumes WHERE VolumeID='${VolumeID}'} GBCurrently Available ${SQL:Select round((VolumeSpaceAvailable / 1024 / 1024 / 1024),1) from Volumes WHERE VolumeID='${VolumeID}'} GBAdditional Information:Server Name - ${Node.SysName}IP Address - ${Node.IP_Address}Server Location - ${Node.Location}~~~~~~~~~~~~~~~~~~~~~~~~Current Status:${Node.SysName} is ${Node.Status}~~~~~~~~~~~~~~~~~~~~~~~~Dell Open Manage Page: HTTPS://${Node.IP_Address}:1311Orion: xxxxxxxx/.../nodedetails.aspx
Thank you all for your help.
Stuart, your script works perfectly, thank you.
Thank you as well for providing the additional infomation however, when i get the alert i get the following
Strange, that was copy/pasted straight from my alert. You Should get this:
Weird,
This line works when in the subject but not in the body
you can either change your email type from HTML to plain text to resolve this or use the following string instead:
Alert: ${FullName} is ${SQL:Select Round ('$@VolumePercentUsed@';,0) from Volumes WHERE VolumeID='@VolumeID@';} Percent UtilizedVolume Size ${SQL:Select round((VolumeSize / 1024 / 1024 / 1024),1) from Volumes WHERE VolumeID='$@VolumeID@';} GBCurrently Used ${SQL:Select round((VolumeSpaceUsed / 1024 / 1024 / 1024),1) from Volumes WHERE VolumeID='$@VolumeID@';} GBCurrently Available ${SQL:Select round((VolumeSpaceAvailable / 1024 / 1024 / 1024),1) from Volumes WHERE VolumeID='$@VolumeID@';} GB
This behaviour should be fixed in the upcoming 10.2 release (according to SW support)
