we are looking for a template or any stuff which can monitor our RSA authentication Manager application hosted on Linux appliances
what processes do you want to monitor? if you just want logging and events, then LEM or the new module for solarwinds may be your best option.
You could always create your own application template.
services like below and authentication failure count, and their details.
replication status between primary and replica instance other application issues
RSA Database Server [RUNNING]
RSA Administration Server with Operations Console [RUNNING]
RSA RADIUS Server Operations Console [RUNNING]
RSA Runtime Server [RUNNING]
RSA RADIUS Server [RUNNING]
RSA Console Server [RUNNING]
RSA Replication (Replica) [RUNNING]
You can create an application template to monitor those services and if there are any event log messages to indicate the failure count you could create an application monitor that checks for the event information and triggers a corresponding alert.
sorry, this is not a windows server. we have hosted the application on Linux OS.
this can be useful for looking for keywords in log files on Linux based systems Linux/Unix File Keyword Monitoring
:-( now I need to find the log file and the key word for service stop and all other stuff which is tedious for Orion Admin or RSA application admin.
I'm sorry I cannot be more help, maybe someone else will have a better idea.
if its possible to configure SNMP on the Linux appliance, then that should help you out and then poll the services using application monitor...
