How are you setting up netflow for a T1 with out it bringing the utilization of the T1 to 90-100%? i have tried to monitor some our or locations accross T1s but it pegs out the utilization of the circuit.
Wow, we run Netflow on quite a few of our T1's with NetQoS and even in our doing testing with Orion NTA we've never had netflow be that much data. Were you monitoring a Layer-3 switch or switches across the link or something? Never heard that before!!
nope, just monitoring a data and voice vlan.
Wow, I'm at a loss, I know netflow data is higher bandwidth than SNMP at times depending on the flows, but that seems very excessive. We're talking like 1-3% on our T1 at the most...
How is your Netflow configured on the router, mostly interested in the commands with "flow" in them. ie: "show run | i flow"
The config looks like this:
interface Serial0/0/0.??? point-to-point description **Circuit ID is ???** ip address 0.0.0.0 255.255.255.252 ip flow ingress ip flow egress frame-relay interface-dlci ??? !ip flow-export source Serial0/0/0.???ip flow-export version 5ip flow-export destination 0.0.0.0 2055!
end
That looks pretty normal, I don't think you need the "ip flow egress" unless this is an MPLS network, can't tell from the config - looks like frame-relay. This is a network "stub", ie: no other networks beyond it, or more specifically, no other Netflow sources beyond it like Layer-3 switches?
I am assuming the 0.0.0.0 on both the interface and flow export destination are actually real IP addresses?
The 80-90% utilization, have you confirmed that its from this router to your server, not some other traffic that just happens to be on port 2055?
You've checked your IOS version vs. IOS bugs dealing with Netflow?
Yes, Most of my locations are MPLS with 1 2811 and a 2960. I have a few locations that have 1 2811, 1 2960G, and up to 3 2960s. I also have 5 branches that are metro-e but those have 3750s and netflow doesnt work on them.
yes, the 0.0.0.0 actually has real IPs in it. I always replace the IPs with 0 when posting to either cisco or here.
Yes, I have verified that the traffic is coming from the router and not some other source.
Yep, I have checked the IOS version against the IOS bug list and it doest show anything similar to my problem.
