Since upgrading to 9.5 the Businesslayer Process has increased substantially. Has anyone else got a similar issue or resolved it. I am running 9.5 Sp3 and APM3.0
Regards
Miron
This service has a memory leak. I have opened case #102994 with support and have been working with them for a month. I am also running 9.5 SP3 and te BusinessLayerHost eventually will get up to 1.6G of memory usage on my server and crash. Will let you know if its resolved any time soon...has been that way since I went to 9.5
I have noticed the BusinessLayerHost using a lot of memory and processor on my system as well. Especially since the upgrade to 9.5 sp3.
I look forward to the hearing what support finds out for you.
We have a fix in test right now and are actively working on it.
Did this get addressed in sp4?
Nope...no love in SP4. Still emailing with support but not getting an answer...my case 102994 was worked by high level of support and they found the memory leak but that was weeks ago and haven't gotten any updates since.
Can someone from Solarwinds please get this fix in the next SP and let us know when to expect it.
brian, I am looking into your case and going to contact you offline to discuss this further
No prob.
