has anyone gotten NPM to monitor bandwidth/error/drop stats on a Nexus fabric extender interface? We can poll/trend this information from the Nexus 5k's but no information is there for the 2K ports.
When we use the if mib if shows all the sats for the ports on the 5k - when it gets to the Fabric extender ethernet ports there is no data for them. Through the CLI there are stats.
I will open a case with Cisco but thought I would look here as well.
The 2k's say they support the IF-MIB... can't you see it there? The docs say all these are supported on 2k:
Configuration MIBs
• ENTITY-MIB
• IF-MIB
• FABRIC-EXTENDER MIB
• CISCO-ENTITY-EXT-MIB
• CISCO-ENTITY-FRU-CONTROL-MIB
• CISCO-ENTITY-SENSOR-MIB
• CISCO-ETHERNET-FABRIC-EXTENDER-MIB
Monitoring MIBs
• RMON-MIB
The CISCO-ETHERNET-FABRIC-EXTENDER-MIB is relatively new:
Not sure what you really get out of there but might be worth a look:
ciscoEthernetFabricExtenderMIB 1.3.6.1.4.1.9.9.691 ciscoEthernetFabricExtenderMIBNotifs 1.3.6.1.4.1.9.9.691.0 ciscoEthernetFabricExtenderObjects 1.3.6.1.4.1.9.9.691.1 cefexConfig 1.3.6.1.4.1.9.9.691.1.1 cefexBindingTable 1.3.6.1.4.1.9.9.691.1.1.1 cefexBindingEntry 1.3.6.1.4.1.9.9.691.1.1.1.1 cefexBindingInterfaceOnCoreSwitch 1.3.6.1.4.1.9.9.691.1.1.1.1.1 cefexBindingExtenderIndex 1.3.6.1.4.1.9.9.691.1.1.1.1.2 cefexBindingCreationTime 1.3.6.1.4.1.9.9.691.1.1.1.1.3 cefexBindingRowStatus 1.3.6.1.4.1.9.9.691.1.1.1.1.4 cefexConfigTable 1.3.6.1.4.1.9.9.691.1.1.2 cefexConfigEntry 1.3.6.1.4.1.9.9.691.1.1.2.1 cefexConfigExtenderName 1.3.6.1.4.1.9.9.691.1.1.2.1.1 cefexConfigSerialNumCheck 1.3.6.1.4.1.9.9.691.1.1.2.1.2 cefexConfigSerialNum 1.3.6.1.4.1.9.9.691.1.1.2.1.3 cefexConfigPinningFailOverMode 1.3.6.1.4.1.9.9.691.1.1.2.1.4 cefexConfigPinningMaxLinks 1.3.6.1.4.1.9.9.691.1.1.2.1.5 cefexConfigCreationTime 1.3.6.1.4.1.9.9.691.1.1.2.1.6 cefexConfigRowStatus 1.3.6.1.4.1.9.9.691.1.1.2.1.7 ciscoEthernetFabricExtenderMIBConformance 1.3.6.1.4.1.9.9.691.2 cEthernetFabricExtenderMIBCompliances 1.3.6.1.4.1.9.9.691.2.1 cEthernetFabricExtenderMIBCompliance 1.3.6.1.4.1.9.9.691.2.1.1 cEthernetFabricExtenderMIBGroups 1.3.6.1.4.1.9.9.691.2.2 cefexBindingConformanceObjects 1.3.6.1.4.1.9.9.691.2.2.1
I would think if you can't see the interface data on 2k's like the 5k's then there's a possiblity there's an issue/bug etc. with version of the code it's running... we've seen this before with some code versions on other switches have known bugs.
Please post the findings. I am having the same issue and would love a resolution.
Are you on the latest NXOS?
I found a free tool on Cisco website that allows you to monitor statistics for Fabric Extender ports.
http://download-sj.cisco.com/swc/esd/03/crypto/3DES/281722751/contract/dcnm_k9.4.2.3.tar
It seems N7k needs license but Nexus 500 and Fabric extenders can be managed without any cost.
We have been working with the Nexus BU and you should be able to monitor them with Orion. If not send me a PM and we can investigate.
Brandon, we are looking at going with the Nexus 5k/2k solution in our data center. Can you confirm whether or not this works in Orion NPM out of the box today? Can you confirm the Orion NPM and Nexus 5k/2k versions this is working with?
We made a couple tweaks in v10 to Nexus support, mainly CPU and Memory on Nexus is done differently than other Cisco devices. However, yes, we have tested against the 5k/2k combination and I have seen it working personally at a customer environment. If you want, let me know and I can hook you up with them potentially.
