No need. We've already confirmed it's a bug and it should be fixed upon upgrade to 6.0
I just tried this and experienced the same results. I choose the option to attach a PDF copy of the config change report to the email and the email has no attachment. I really need this feature to work, because my Lotus Notes email client crashes when trying to open the emailed report, due to the size of it I guess. If if could send as an attachment, it would work much better.
Did anyone find a solution to this?
Can you both please open support tickets on this issue and reference this thread? I'd like to make sure this is reproduced in house.
Same here. Case #108296 opened with support.
So it seems that this is a bug.
Email from SW Support:
Jeremy,Upon researching this, I found that this is a known issue and it is being addressed by our development team. This case will stay open and you will be notified when it has been resolved.Currently, all I have is that it will be resolved in a future release of NCM.Thank youLorenzo Brizeño • SolarWinds • Technical Support Rep
Yes, it's a bug. I've got this on the list and it's high priority to fix.
Just ran into this one myself. Considering this is a documented bug should I bother with a support ticket?
