That link is dead, can you provide more information on this. I would like to use putty for my Orion site.
Thanks.
Link has been updated -
I've attached the zipped Reghack file for your convenience.
I have asked for this feature for awhile now. Like Cirrus you should be able to define custom tools to use. You should be able to remove those icons, or add icons that can be used for SSH, etc. BB
has there been any progress from solarwinds on this? I dont like having to "hack" the registery or anything like that to be able to support SSH to my devices.
HI dclick--
I'll see that the product manager gets this to try and get you an answer. In case you are wondering what NPM development is working on for the next release, look here
Our networking group has asked this same question numerous times. It kind of blows my mind that telnet would ever be used in any production network environment. Is there anything we need to do in order to get this escalated as a feature request? More often than not NPM is the first place we go when a device has issues. It would save a lot of time to be able to click a link that triggers an SSH client to connect to the device.
Thanks, Iain
Hi Iain--
The Product Manager is aware of your request.
M
