Hello;
Is there a way to tweak the NTA Graph to load faster or something?
What are the dependencies for this module (ei : IIS)?
Thank you
Which version of NTA? The screenshot looks like NTA v4.x. Assuming 4.x, is your NTA server on a 32 bit machine or a 64 bit one, i.e., are you still storing the NTA data in the SQL database or the new FSDB (Flow Storage DB)?
Hi!
4.0.3
64 bit
own db. - same as orion
FSDB
What are we looking at in the screenshot above? Is this data from all of your sources, or a specific netflow enabled interface?
If you look at such a graph (top receivers over one hour) on a single interface, is it fast?
This is from all sources - it take like a minute to "render", the data below comes ok, but it takes for ever..
Is it fast if you look at just one interface using the same graph? Do you happen to know how large your FSDB is?
FSDB = 265 G
65 Days Retention
The best course of action would probably be to open a support ticket so we can do a deep dive: SolarWinds Customer Support - We're Here to Help
Generally, to improve FSDB performance, it is recommended to move it to dedicated machine, dedicated drive.
