I don't think that version of IOS supports the ip flow ingress and egress commands. You'll have to use the "ip route-cache flow" command. That command only captures data on the inbound traffic, so to see both inbound and outbound traffic, you'll need to put the command on both the ethernet and serial interface of the router. Hope this helps.
I'm not sure I understand your question, but if you mean how will you see traffic coming into both sides of the router, you'll have to add the ip route-cache flow statement to each interface's config. If this isn't what you mean, just let me know.
config t
(config)#int ser0/0
(config-if)#ip route-cache flow
(config-if)#int fa0/0
I'm not sure you can export from multiple sources. For the NTA, your export source IP address needs to match the IP address Orion is using to monitor the node. Why do you need to export from both interfaces?
Yes, that is correct, as long as 1) you have a version statement and a destination statement in your config and 2) the IP address of your source interface matches the IP address Orion is using to monitor that node. I haven't tried configuring version 9 NetFlow yet, so I'm still using version 5. My statements look like this:
ip flow-export source [interface]
ip flow-export version 5
ip flow-export destination [IP address of Orion server] 2055 (default port that Orion listens on for NetFlow data)
int x
ip route-cache flow (or ip flow ingress on current versions of IOS)
Hope this helps.
