quote:Originally posted by MithrilhallYou say virtually identical devices; what IOS are you running on the affected device and the identical devices?
quote:Originally posted by nwoodHas anyone reading this experienced CPU spiking (90%+) on a Cisco device as a direct result of regular SNMP polling? Every 5 minutes (to the second), I'm getting a CPU utilization spike on the device to which our NPM server is connected... but not any of the other, virtually identical (as in models, configs, loads, connections, etc) devices.Reading Cisco documentation, it sounds like it's nothing to be concerned about as process prioritization won't allow low-priority stuff to affect routing, etc. I also recognize that there's a difference between how things should work and what's actually going on.If anyone has had experience with this and has found a workaround/fix, I would love to hear about it. Thanks all.
quote:I had what sounds as something very simular. I Upgraded the Orion server to Server 2003. The problem still occurred. For the past week I've been exiting the Orion system managered when I've been finshed with it. I used to just minimize it. It's been better this week. I easiest way to clear the problem was to reboot the Orion server.Brain RiessHamilton, OntarioCanada
quote:Originally posted by nwood quote:I had what sounds as something very simular. I Upgraded the Orion server to Server 2003. The problem still occurred. For the past week I've been exiting the Orion system managered when I've been finshed with it. I used to just minimize it. It's been better this week. I easiest way to clear the problem was to reboot the Orion server.Brain RiessHamilton, OntarioCanada
