Does anyone know how to change your username on Thwack forums?
Thanks!
Nexicom,
What would you like your username changed to? I can change this for you.
Danielle
Many thanks - can you change it to pstewart726 by chance?
Your username has been changed to pstewart726.
Danielle, Are you still able to change a username?
Can anybody Change my Username to SARDAR?
Thx in advance.
FK
Hi sardar,
I just changed it. Let me know if you need help with anything else.
Maria
Thx a bunch
Regards
Can you change my username too please? ashaikh77
ashaikh77 - your username has been changed :-)
Please change my user name to arman08
Hi arman08, your username has been updated. Please let us know if you need anything else.
please change my username to PanT
You are all set pant
Can you change my username to Carl.H?
Cheers
carl.h, sure. It's done!
Super dooper, thank you very much....
Um, is there another way to change a username? This seems like an odd way of going about it.
Hi marilyn.m.leonard.civ@mail.mil - for right now this is the avenue to get your username changed. You can message me, DanielleH or maria.bungau what you'd like your username to be or just reply to this message. :-)
Can I change it to mmlciv?
mmlciv, sure. I took care of it, so you should be good to go.
Can I please get my username changed to PMaldonato?
Thank you.
I can only assume that my Thwack user name is the same as my log in but when going to my profile I don't see anything that says: this is your thwack username.
mfrick@fhprd.org - yes, your username is your login name. You're also correct that when you visit your profile it doesn't show your username. I can tell you your username is currently your email address. We can change that if you'd like.
Please change my user name to just mfrick please! Thank you!
You're all set mfrick ️
Please could someone change my username to jtsouthcombe
Thank you
You're all set John Southcombe ️
Hello,
Can you please change my username to telekomnyy?
Your username has changed telekomnyy
Could you please change my username to lll8lll ?
You're all set lll8lll
Can you please change my user name to idrewpage ?
My old user name is no longer relevant.
idrewpage, it's changed.
Would it be possible to please change my username to User?
Can someone please change my username to Affiniti1. Thank you.
You're all set affiniti1!
Hi Danielle, could you change my username as well?
I would like it to be the email address associated with my account. If this is possible please let me know and I will send it to you.
Thank you!!!
Hello, would you please change my username too? Change to MikeL1742 if it is available.
Thanks.
You're all set mikel1742!
Can I get my username changed over as well? Something like T.Wall would work? Thanks
Can I get mine changed as well, is 1pP@ck3t$ available
if special characters are not allowed then ip.packets would work
Thanks again
Could you change mine to jenyx please? Thank you! mrs.alterego DanielleH
Hey Jenny, we have two accounts on file for you, jenny.solomon and jennysolomon. Which account username would you like us to change? We can also go ahead and deactivate one of the accounts if you would like to just have one and avoid any confusion.
Hey Jeff, your username has been changed to ip.packets!
I'd like to have mine changed to MrGote if possible. Thank you!
That username unfortunately already exists. Is there something else you would like to change it to?
No I'll stick with what it is for now. Thank you or checking it.
Thank you for the quick response!
Hello lindsey.serrano Please deactivate the username jenny.solomon. If you could change the username jennysolomon to jenyx please, that would be great! Thanks again!
Alright you're all set! https://thwack.solarwinds.com/people/jenyx
lindsey.serrano Any chance of getting change made?
It's been changed!
May I have mine changed to mbuchan3 or whatever number is available if that is not. Thank you!!!
It's been updated for you!
Awesome, thank you very much!
I am leaving my job and would like to change my username. Can you please change it to:
NMHI_IT
Your Username has been changed nmhi_it
Can I also change my account name to Captain Crunch
Can my user name not have the @yahoo.com part? just kzerokenshiro please?
Can you change my username to "Sunny". Please instead of sunayan.
Hi Sunny,
Unfortunately that username is already taken. Is there something else you would prefer?
Sunny Smith.
I don't know how to change, but i don't think is a problem
It has been changed to sunnysmith!
Is this still doable? I would like my username changed from gravely to gravtech.
Hi Bryan,
Your username has now been changed to gravtech.
Can you please change my username to JohnS? If that is not available please use JohnS1002
Thanks...John
Hi John,
JohnS has already been taken so I went ahead and changed it to JohnS1002 as requested. Let us know if there's anything else we can help you with!
Is it possible to change my username to James.White if not available AAAJameswhite, I set it as my email which I do not want public on each forum, There should be a Display Name field that is used for this. People can easily identify their accounts, which may link be used on other websites. I think is a real security concern.
Hi James, I sent you a DM.
Hi Wendy, is it possible for my username to be changed to "megsofram" ? Thank you in advance!
Hi Megan,
Your username has been changed!
Same here... I made my Thwack username my email by mistake. Can a friendly passing moderator change it to "TheDM" / "TDM" or something like that please.
Hi David,
Your username has been changed to TheDM.
Hi - Is it possible to change my username to RandiS?
Hi Randi,
Your username has now been changed to RandiS.
Hi, could I get my username changed to susan.seo? Thank you!
lindsey.serrano wabbott
susan.seo
Your username has now been changed! Be sure the next time you login that your username is now 'susan.seo'.
Also, Lindsey no longer works at SolarWinds - I am the new Community Moderator. If you ever have any questions, please do not hesitate to reach out to me!
Would it be possible to change my user name please? Hoping for KevinM or if that is taken then KMooney. Thanks!
Can you update my username to kenp?
Could someone change my username to bcook17?
Your username is now changed
Is it still possible to get the username changed? If so, can I have mine changed to deonaanne72?
Thank you in advance.
Dé
Can mine be changed to DWV1970
Hey Dave,
I just changed it for you!
Hi Brett,
Would you be able to change my username please? 'arianne.t' would be great.
Thanks in advance!
Absolutely! I'm updating it right now for you.
Can I get my username changed also?
Hello Dana - I'd be happy to update yours. Just DM me what you'd like to change it to.
Hi, can you change my username to bluenose0 please?
Sure! This update has been made.
can you please change my username to franklin.gonzales
had a typo error when registering. thanks
Hey Franklin - this has been updated. Thanks for reaching out!
thegreateebzies wrote:Hey Franklin - this has been updated. Thanks for reaching out!
thanks a lot! i'm now able to login using the new username.
Hey,
Can you please change my username to "nikhil.nair" ?
Hello Nikhil,
This change has been completed. Thanks!
Please change my username to ice.quake
Thank you!
Your Username has been updated to what you requested. Give it a couple minutes and refresh to see it take effect!
can you change my username to omallk92, thanks!
omallk92 this has been taken care of. Let us know if you have any issues logging in.
Hello.
Can someone change my username to JustinA ?
justina this has been updated!
HI,
Can you change my username to mpphillips?
Thanks!!!
Done.
Can I get my username change to mfunderb? It is currently my email address. What would also be really cool is if I could change it myself on my profile.
Done and done
Hi yumdarling,
Can I request an username change also?
Would like to have it changed to my email address.
All done
Is it still possible to change Thwack usernames? If so can mine be changed to himem386 please?
It is @himem386 - just remember to update your stuff.
Just for future reference, if anyone would like to change their username, please send an email to THWACKADMIN@SOLARWINDS.COM. I am in the process of moving the emails to the Service Desk so the other admins can help track such requests.
