In Node Details.. on the top right there are links to Telnet, RDP.. and so on..
Is there way to add a link to HP ILO and HP Insite Manager attached to that server?
But I would have to add a link for each server... it won't populated for the server that I am looking at
No, just on the master view that you use for your servers. In other words, say you use a details view called "servers" for all server nodes. Just add the User Defined Link resource from the Miscellaneous group to the Server view and it will be there on any server that you select. USe the http://${IP_address}: port number format.
Sorry, I meant ${IP_Address}. Case is important.
Is there a list of these "variables"?
thwack.com/.../AdvancedAlertsandVariables.pdf
Also, here is the list of Node variables from the Admin. guide.
Thank you guys.. its up and running..
to recap for anyone else reading this..
used https://${DNS}:2381 to get to HP Insite on servers
used https://ILO-${DNS} to get to HP ILO
added both of these to "links"
But this does bring up another question..
I created some custom fields in "Custom Property Editor".. is there any way to bring those fields into a variable?
