I am using switch port mapper 10 and trying to map a Nortel 8600 core switch but keep getting the error "ip does not support the bridge mib". Any assistance would be appreciated.
akajee,
have you tried turning off GetBulk in Switch Port Mapper? Go to the gadget settings, and on the Port Map Settings tab, uncheck "Use GetBulk". Then try again.
Hi and welcome to Thwack!
I wonder if you can you run a MIB Walk (from Engineer's Toolset) against the device?
This might be a timeout: did you increase the timeouts to maximum?
Also check the Switch Port Mapper KBs below:http://knowledgebase.solarwinds.com/kb/categories/Switch+Port+Mapper/
Thanks for reponding. I can run the MIB walk but I do get a timeout after a while. I have increased the timeout but the error come almost instantly almost as though it never even tried to contact the switch
A Wireshark Packet capture would the next I'd suggest logging a ticket on this.
That worked via the switch port mapper in the workspace studio, Thanks
How do I get it to work outside the studio?
what do you mean with the "outside"?
Apparently, your device does not fully support SNMPv2 (GetBulk query). You should check for software update with the vendor.
you get a spm under classic tools (start menu) and there is another on within the workstudio application. The start menu app give the bridge mib issue.
In the classic SPM, go to menu File - Settings, and you will find "Disable SNMPv2 packets) on the SNMP tab.
