We are trying to figure when this started. We think it was when we went to OPM 9.5 sp3, I applied 9.5sp4 yesterday.
Whenever I click on an interface in the Top 10 NetFlow Sources box on the Summary screen, I get the following error:
RESOLVED in Support - case
I suggest you open a support ticket for this one.
Will do. Figured I'd see if anyone had run across it and had a quick fix. Thanks!
You're in luck - I've seen this a few times.
Basically put - the NetFlow views were built with no resources (most likely during an upgrade)
Simply delete those views - and then re-run the configuration wizard (Database and Website) - and your views will be restored.
By views do you mean remove the Top XX Netflow Sources... from the summary screen? Do you mean remove the netflow sources? Then run the wizard?
I've done both of these and re-run the wizard a few times. No luck.
No, delete the actual view from "Manage Views"... If you are not able to do it from the web console, you can follow these instructions:
** As with any database manipulation - please ensure you have a working backup prior to completing these steps:
Open the Database Manager
Expand the Orion Database - and the Tables
Double-click on the "Views" table
Select "Run-Query" and hit "Refresh"
Select "Read-Write" Query
Right-click on the ROW for your NetFlow View(s) and select "Delete Selected Rows"
Now re-run the config wizard
Ahhh, ok. I found it in Manage Views. Delete every Netflow entry?
Most likely yes - You're key indicator will be to "edit" the view - and if there are no resources in the view - go ahead and delete the entire view...
Your other option is to "rebuild" the view by adding the appropriate resources, but this can be more time consuming that just deleting the view and running the config wizard.
Hope this helps you and any others out there,DB
