How do I enter command to display Custom Properties I have defined? Do I have to pick that out of the database?
We have that as an open enhancement in the system.
Have you seen this blog post I did here
Thanks. Yes and it is a big help listing the variables in one location. It did not address the "Custom Properties" variables that we create. I did enter them in the same manner and they did not appear to work. The when I looked at it again this morning the contents of the "Custom Variables" were present in the Map Tooltip Hover-over.
It would also be great to be able to 'customize' the hover-over pop-ups in other display locations other than maps, such as in the All Nodes - Tree or alerts section.
Thanks again for the help.
Hi, is this still a planned enhancement, or is it available? If so, what version?
Many thanks!
L
I assume you mean to extend the hover over popups to all the website? If yes, then the answer is this is still an open enhancement
Brandon - Why not have the Custom Properties enumerated from the database and just allow the user to select them? It eliminates typos, eliminates questions on which variable can be used where and is self eplanatory in terms of use.
John
An idea we will take into consideration
I think the database selection is a great idea; however, it is limited to the selections entered. Perhaps if it had a base list to choose from and allowed others to be added via GUI.
