So is there a way for this to work in version 9.1?
What is it you are wanting to know exactly. This thread is four years old and a lot has changed since then. If the device responds to SNMP requests then Orion can manage it.
yea probably should have startred a new thread. I am wanting to use the dell open manager mibs and receive the snmp info in orion 9.1
If you know the OID you want to monitor (for example, by copying it from the Dell site), you can use it with UnDP. Just paste it into the OID field. You don't have to wait for us to add the latest version of that mib.
maybe this thread will help with those...
Ok thanks i'll try this out. Thanks again for the help.
