Is it possible to create a view on the web console to monitor the signal of the wireless cards in a cisco 2811? I've fumbled around and can't seem to find out how.
Dave
Thank Yann.
Looks like I found the issue. The OS we currently are running on the router supports the card but not the MIB. So we have to upgrade the OS on every router, then we should be good to go.
I am configuring a number of cisco 2811 routers with hwic-3g-gsm cardsI've been asked to find out a way to get the radio signal status/levels to show in web consoleHas anyone else achieved this & if so, would you care to share?
What version are you on? Have you tried creating a UnDP, see here
v9.5
We did try...may have the incorrect MIB. Have to do more looking.
Thanks!
Does the Wireless card have it own Admin IP and configuration or is it just considered a part of the chassis?
I believe it's seperate...I'll check and get back...Sorry, I'm a noob..
No worries, if seperate and you are running NPM 9.5 and it supports the 802.11 MIB, you should add it to Orion
But it's not 802.11...I have 1 router in every state, with a circuit to each. These cards are cellular in each router to back-up the circuit in the event it drops. The MIB I used before must have been the one you spoke of, as all I could see then was my local wireless host controllers.
