When I try to publish to the separate web server, I get the prompt below and the publish to the remote web server fails. Any ideas?
Will
run-time error '13'
Type mismatch
I have the same error (Case #2544) which I reported to Solarwinds on March 21st.
I have had a few suggestions, but nothing that has resolved the issue - it's still open. While not glad you also have this issue - it might prompt some further investigation.
Sav.
uh, What?
It got cold outside so they closed the ticket?
:-) just a change control on the customer's end-
Support is correct - they closed the case until we can schedule a re-install of Orion. Given we have a large installation (4000+) nodes, I have elected not to do this until 8.1 is available.
We have comfirmed both the DEP settings and Admin rights as requested by Support - product re-install was the last option requested.
As a bypass, we are performing a manual copy of the maps.
"Reinstall Orion"? You have *got* to be joking. How about actually troubleshooting the problem rather than just crossing your fingers, cuasing the customer a *lot* of pain and effort just in the hopes that the issue goes away?? I've been hearing a lot of "reinstall [product-x]" from support and that's just not a reasonable troubleshooting response.
sorry to disappoint but reinstalling does resolve many issues -but of course some problems require further troubleshooting-
Have you opened a particular case that can be referenced for discussion?
