quote:Originally posted by GrabowskiI also had the problem with jobs being stuck in the "running" state. The cure was to have an account that had local administrator privileges run the job.
quote:Originally posted by BryanBeckerThanks....I have a call into them as well.BB
Thanks!
Victor
Has everyone experiencing these issues submitted a case with support (either online or by phone)? I want to make we're tracking this inventory issue properly. If you have, can you please post your case # so I can see where we are on this issue.
Wow....I didn't realize I opened this in 2006...yikes. I'm not sure what my case was. We have 2 Cirrus servers....one has about 600 devices the other has about 200. The 600 server inventories everything in about 3 1/2 hours.BB
So I installed the new version of cirrus (v.4.0) on a new server where before I just upgraded from the privous version. I removed the cidr & route tables and only running a inventory on my routers.
So far its working good but the minute I add a switch to the mix I get the lockups.
Please open a ticket on this one. Those are pretty clear repro steps so we'll want to verify this is fixed in 5.0
Case #56745 created
Yes, I'm having the same problem
In the case cited above, the solution was to manually update the credentials in the database.
