I have come across pings returning negative response times before. If I remember correctly it was caused by driver problems relating to AMD Opteron CPUs in our case.
I found the below text in another forum post at http://www.brianmadden.com/. This matches the symptoms we had although I don;t know what CPU's you use.
"you can get the driver here. It's at the bottom of the page. www.amd.com/.../0,,30_182_871_13118,00.html AMD Athlon 64 X2 Dual Core Processor Driver for Windows XP and Windows Server 2003 Version (x86 and x64 exe) 1.3.2.16 - Allows the system to automatically adjust the CPU speed, voltage and power combination that match the instantaneous user performance need. Download this Setup Installation program (EXE) to automatically update all the files necessary for installation. This package is recommended for users whom desire a graphical user interface for installation. This .EXE driver is a user friendly localized software installation of the driver designed for end-users. This driver supports AMD Athlon 64 X2 Dual Core processors on Windows XP SP2, Windows 2003 SP1 x84 and x64 Editions. "
Did anyone find the solution to this problem? I'm experiancing the same kind of behaviour on our current platform. I'm running NPM version 9.5.0 at the moment On the dos prompt, i get simular results as seen in orion.
Wilfried
Hi Wilfriend--
You are posting to an old thread so I'm going to send your post to the product manager and see I can get you an answer.
M
Also, what does your Orion server look like? How many elements are you monitoring on your poller?
Hi All, the server is using dual-core AMD Opteron, processors 2218. I found the drivers you mentioned and am updating them now. Our poller is doing the following load :
nodes : 789, volumes 4956, interfaces 402. Although we have 2 pollers and the second one does : nodes 118, volumes 242 and interfaces 44. Even on the second poller we are seeing this behaviour.
I will let you know the result of the upgrade in driver.
Thx for your help, Wilfried
Drivers were updated and the problem seems to be resolved. Thx for all the support.
