I get the following error on all pages.
I have rerun the wizard and re-installed. Any ideas
Permissions yes but I would hesitate to think it's DB related.
See my steps in this thread-
Also make sure the Distributed Transaction service is started. If that still does not work you will need to set the DEP settings to allow for essential windows and programs services only (requires reboot)
Mark-
Thanks for the help. As I was going into Component Services, it was brutally slow. I remembered that our MSDTC sometime gets FUBAR'ed. I entered the following at a command prompt that relieves that problem msdtc -resetlog, then net start msdtc. I went in and it was responsive. I delete the COM Application, then re-installed just the web portion, but I still got the error. I then reinstalled the whole app and I still get the error. I also checked and the COM Application has not been reinstalled. Anything else I can try?
Let the Configuration Wizard run completely through...
DEP?
I've done that too.
Hmmmfff, still get the error. Could this be caused by DB permissions?
A little background on this issue: I tried installing Netflow module (which failed), uninstalled the Netflow module, started getting this error.
and BINGO was his NAME-O. I had to add my account in the permissions. Thanks Mark!
I had that problem, which was caused by having 'User must change password on next logon" on the SOLARWINDS_WEBSITE local user account. See my link - hope it helps.
