I have a HP C7000 chassis that is reporting the OA CPU as pegged at 100%. HP though say it is only at about 30%. Can anyone tell me the specific OID that NPM uses to poll for CPU utilization?
Just curious and I know it doesnt help but what version OA administrator are you running? I've got anywhere from 3.50 to 4.01 and my CPUs are reporting normal.
Good point. I find we do have another chassis which is (apparently) reporting correctly at around 14%. I'll ask the SME to see what the difference is.
He reports they are both at 3.71 .
So you have two separate OAs you are monitoring, both are using the OA FW of 3.71 yet one is correct and the other is pegged? That seems odd.
I agree. What is odder though is that HP is saying (via the OA management GUI) that the CPU is normal.
One of them is most certainly wrong!
Just for kicks - Can you delete it and re-add it to npm?
Upgrade OA
No change. Still 100%. I will dive deeper with the Chassis SME and see what we can learn.
Hey Folks. I got same situation here: 6 enclosures c7000 at 3.71 version, 3 reporting 100% CPU and 3 normal. Any news about this?
Wondering if anyone got to the bottom of this? Was it an OA version issue?
