I have setup a Parent map and linked a child map to it. When an interface on a switch goes down you don't get notified on the parent map only when the hole node goes down. Anyone have a work around?
good deal. Once you get one in place, it isn't too bad to replicate and re-map objects.
admin -> web console settings -> Status Rollup Mode
check help if questions about what selection does what.
I've already tried this setting and it's not working. Any other ideas?
hm, that should have worked - my understanding. Another thing to try is "show child status" on the map to child object, but that will just show a little dot in bottom right corner.
I would open a ticket. Please post the results.
It works if the whole node goes down but not just a port. I opened a ticket and it looks like it's not supported which seems like a pretty common request.
I think I know what you are trying to do now.
I resolved this (a lot of work) by using sub maps that have all of the individual ports on it.
So I have 6509. I have a map that has the 6509 icon, then I have 8 sub-maps that are of the blade icon. each port has an object overlaid that is tied to the interface in orion. see below/attached:
Here are some of my custom icons
That's what I was looking for. Support said to put the interfaces on the map but wasn't sure how that would look. I like how this looks with the objects. Thanks I'll put this in.
