Recently we migrate all our nodes from SNMP v2c to SNMP V3,
but actually, some some times the collection of data stops,
and is required re-ingress the SNMP v3 credentials of the nodes
in status Unknown on Orion!!!!
Help!!!!!!
try with SP5, on fixes list it is our bug :-)
Even i have this issue due to which i am unable to upgrade to 9.1
All my approx 800 devices are working on SNMPv3 and poller is unable to poll any of them after few cycles of poll. even restarting the NPM service or server itself does not help.
If i downgrade to 9.0 SP2 everything works just fine.
Have you each opened a Support ticket?
Yes the support ticket is opened
Case #64859 - "Unable to poll CPU utilization after upgrading to NPM 9.1 on SNMPv3"
Opened since : 23/10/2008
Case #63695 - "Unable to poll CPU utilization after upgrading to NPM 9.1"
opened on 16/10/2008
Support team is still working on this and no fixup received till date. I am stuck on NPM9.0 SP2 and cannot upgrade
I've checked on your issue, and engineering is investigating it.
I thought it was just me - The nodes are online, they poll fine, but I have to re-add all of the nodes every once in a while whenever I use snmp v3.
This happens whenever the node can't poll for a short while (like an access list, or outage), and it comes up again. I know the interface IDs are the same, but they appear 'blue' on the web interface implying it's unmanagable.
Is this just for Cisco devices? Can anyone confirm or deny?
If anyone else is having this issue, please call support and get us diagnostics.
I carefully validated my configuration. I was missing a specific SNMP view that was preventing my nodes from being able to poll. This was administrative error on the router and not the fault of solarwinds.
My minumum view for solarwinds is:
snmp-server view monitoring system includedsnmp-server view monitoring interfaces includedsnmp-server view monitoring ip includedsnmp-server view monitoring ciscoMgmt includedsnmp-server view monitoring chassis includedsnmp-server view monitoring iso included
I already have SNMPv3 running fine with 800 nodes on NPM 9.0
The problem comes only when i upgrade to NPM9.1
So i don't think it is a device or configuration issue.
Since i have only cisco devices deployed in my network i can't say for other products
