Hello,
Can i manage all my vlans in the network ?
When i created subnet mask in IPAM i mention his vlan id:
Now i added the "list of all vlan's" view but i cant see any vlan.
Does anyone know how configure this ?
Regards
Rafi
OK
Thanks.
The "List of All Vlan's" view is not populated by IPAM at all. The VLAN ID in IPAM is just for your records within IPAM.
If you want the "List of All Vlan's" view to be populated, you need to select the VLAN option in List Resources for the Node.
O.k i understand !!!
For now all my BB switches are Nortel and i don't have this VLAN option in "List resources" .
I have 3 trapeze wireless controllers, i marked the vlan options and i can see the vlan list in the device node.
In IPAM i added the view of "all vlan list" but the view is empty, someone know why ?
The view "List of all VLAN's" need to be added to say the Home or Network tab. I'm not sure how you added the view in IPAM.
Thanks for your replay,
I added the "List of all VLAN's" to IPAM with customize page.
I added it to network tab also, but unfortunately its the same i cant see the vlan list
Then I'm not sure why it's not populating. Log a support call to see what they say.
