Does anyone know if there are any templates for;
Citrix Provisioning Services Version 7.6
Citrix Farm Controllers Version 7.6Citrix Director Version 7.6
Windows 2008 Server with Citrix Virtual Desktop Agent Version 7.6
Thanks!
I believe the following templates are what you are looking for.
Thanks but I would also like to monitor the Xen hosts also - do we have anything for that?
By the "Host" what exactly are you referring to?
The physical Linux XEN server hosting the farm VMs and PVS server
Thank you
The Virtualization Manager team is currently working on native XenServer support.
Is there an update for that native module, and is it separate from SAM, or will it be included in an update?
XenServer support would be a feature of Virtualization Manager, which is a separate Orion module from Server & Application Monitor.
