Where can I find the filter that I need to fix for the following report?
Could you elaborate on what you are trying to filter on for this report?
Thank you for helping me out.
What we ran into is a report that does not seem to work. From our "Home" screen we click reports, expand "Historical Traffic Reports" and select the report "Total Bytes Transferred by Node - Last 7 Days". we get a page that indicates the following:
It is a bug. What you will need to do is add the interface ID from the select Fields Tab- and make sure that it is above the Total Bytes Received field.
That worked for that report and I fixed the report for 7 days, last month and this month. However there is yet another report that I need your help to fix. Average and Peak Traffic Rates - WAN Interfaces Last 7 Days does not show any info.
I was running it from a web interface.
I just went into Report Writer from Net Perf Mon and hit the execute button. The window is now stuck with an Hour glass, the box indicates "formatting data..." It began counting down and is now stuck at 3000 records.
Well it sounds like one of two possibilities: The SQL Server is responding slowly and can't write the report query fast enough. Check the event logs of both the Orion and SQL Servers and see if there are any events such as "Main Task Data Reader" or "Connection Timeout". Also watch the CPU utilization on the servers when you pull a report - SQL can be a resource hog and perhaps the server just can't keep up with it. The other possibility is that there is just too much data to be sorted through in a reasonable amount of time. What are your settings as far as keeping old data? You can find these by going to File -> Orion Network Performance Monitor Settings in the System Manager. The Database tab should have this information on it.
You could also try to change the query a bit. Keep in mind that how you order the query has a big impact on the DB response time. Make sure you have the most specific query first. You can also try to incresae the DB timeout varibales.
The timeout settings for SolarWinds that can be adjusted as follows: Go to C:\Program Files\SolarWinds\Orion and find the file SWNetperfmon.db Open the file with Notepad. At the very bottom, there are two timeout values - Connection, and Database Command.Increase those to 1200 each, save and close the file.
