Im wondering when we will be able to use Orion on Server 2008?
regards
It's scheduled for a future release, but not v9.0.
When is v9.0 due out?
Currently in Beta now - We can't give a precise date, but it's fairly soon.
Ah ok thanks.
Sorry about all the questions but i presume V9.0 will be able to update previous versions?
Ok
Thanks for your help guys.
Have some new blade servers and the sys admins are wondering if we can go forward with a 2008 build or if they need to make a 2003 build for the Orion server. The database is on SQL so it is being set up on 2008 anyway.
I know the official position is that Orion does not have 2008 support yet but will it run on it?
If not I would like to resurface this and ask if there is any indication of how long before it will?
