I need to show a report listing all user accounts that have never logged in. How do I format the Where statement to do that? I think those are the accounts that have a LastLogin value of "1/1/1900", right?
What kind of accounts are you using? Orion or AD/SAML?
If your using AD/SAML you would not see records until the user actually logs in. You would have to pull the AD group in compair against who is missing from Orion DB.
If your using Orion accounts you can reference the last login date. The default date is '1900-01-01 05:00:00'.
SELECT AccountID, Enabled, LastLoginFROM Orion.Accounts AWHERE A.LastLogin != '1900-01-01 05:00:00'
Anyone please?
You might also like this dashboard (sorry I don't remember the post to give proper credit to the creator)
'Custom SQWL Query' resource
SELECTAccountID AS [NAME],CASE WHEN AccountType = 0 THEN 'Orion Service Account' WHEN AccountType = 1 THEN 'Local Orion' WHEN AccountType = 2 THEN 'AD Individual' WHEN AccountType = 3 THEN 'AD Group' WHEN AccountType = 4 THEN 'Group Member'END AS [ACCOUNT TYPE],CASE WHEN AccountType IN ('0','1') THEN '/Orion/Admin/Accounts/images/icons/orion_generic_icon_orange.gif' ELSE '/Orion/Admin/Accounts/images/icons/windows.gif'END AS [_IconFor_ACCOUNT TYPE],CASE WHEN Enabled = 'Y' THEN 'Yes' ELSE 'No'END AS [ENABLED],CASE WHEN Enabled = 'Y' THEN '/Orion/Admin/Accounts/images/icons/ok_enabled.png' ELSE '/Orion/Admin/Accounts/images/icons/disable.png'END AS [_IconFor_ENABLED],Expires AS [EXPIRATION],LastLogin AS [LAST LOGIN],CASE WHEN LimitationID1 IS NULL OR LimitationID1 = '0' THEN 'None' WHEN LimitationID2 IS NULL OR LimitationID2 = '0' THEN 'None' WHEN LimitationID3 IS NULL OR LimitationID3 = '0' THEN 'None' ELSE 'Limitations Exist'END AS [ACCOUNT LIMITAITON],CASE WHEN AllowAdmin = 'Y' THEN 'Yes' ELSE 'No'END AS [ADMIN RIGHTS],CASE WHEN AllowAdmin = 'Y' THEN '/Orion/Admin/Accounts/images/icons/ok_enabled.png' ELSE '/Orion/Admin/Accounts/images/icons/disable.png'END AS [_IconFor_ADMIN RIGHTS],CASE WHEN AllowNodeManagement = 'Y' THEN 'Yes' ELSE 'No'END AS [NODE MGMT],CASE WHEN AllowNodeManagement = 'Y' THEN '/Orion/Admin/Accounts/images/icons/ok_enabled.png' ELSE '/Orion/Admin/Accounts/images/icons/disable.png'END AS [_IconFor_NODE MGMT],CASE WHEN AllowReportManagement = 'Y' THEN 'Yes' ELSE 'No'END AS [REPORT MGMT],CASE WHEN AllowReportManagement = 'Y' THEN '/Orion/Admin/Accounts/images/icons/ok_enabled.png' ELSE '/Orion/Admin/Accounts/images/icons/disable.png'END AS [_IconFor_REPORT MGMT],CASE WHEN AllowAlertManagement = 'Y' THEN 'Yes' ELSE 'No'END AS [ALERT MGMT],CASE WHEN AllowAlertManagement = 'Y' THEN '/Orion/Admin/Accounts/images/icons/ok_enabled.png' ELSE '/Orion/Admin/Accounts/images/icons/disable.png'END AS [_IconFor_ALERT MGMT],CASE WHEN AllowUnmanage = 'Y' THEN 'Yes' ELSE 'No'END AS [ALLOW UNMANAGE],CASE WHEN AllowUnmanage = 'Y' THEN '/Orion/Admin/Accounts/images/icons/ok_enabled.png' ELSE '/Orion/Admin/Accounts/images/icons/disable.png'END AS [_IconFor_ALLOW UNMANAGE],CASE WHEN AllowDisableAction = 'Y' THEN 'Yes' ELSE 'No'END AS [ALLOW DISABLE ACTIONS],CASE WHEN AllowDisableAction = 'Y' THEN '/Orion/Admin/Accounts/images/icons/ok_enabled.png' ELSE '/Orion/Admin/Accounts/images/icons/disable.png'END AS [_IconFor_ALLOW DISABLE ACTIONS],CASE WHEN AllowDisableAlert = 'Y' THEN 'Yes' ELSE 'No'END AS [ALLOW DISABLE ALERTS],CASE WHEN AllowDisableAlert = 'Y' THEN '/Orion/Admin/Accounts/images/icons/ok_enabled.png' ELSE '/Orion/Admin/Accounts/images/icons/disable.png'END AS [_IconFor_ALLOW DISABLE ALERTS],CASE WHEN AllowDisableAllActions = 'Y' THEN 'Yes' ELSE 'No'END AS [ALLOW DISABLE ALL ACTIONS],CASE WHEN AllowDisableAllActions = 'Y' THEN '/Orion/Admin/Accounts/images/icons/ok_enabled.png' ELSE '/Orion/Admin/Accounts/images/icons/disable.png'END AS [_IconFor_ALLOW DISABLE ALL ACTIONS],CASE WHEN AllowCustomize = 'Y' THEN 'Yes' ELSE 'No'END AS [view],CASE WHEN AllowCustomize = 'Y' THEN '/Orion/Admin/Accounts/images/icons/ok_enabled.png' ELSE '/Orion/Admin/Accounts/images/icons/disable.png'END AS [_IconFor_VIEW CUSTOMIZATIONS]FROM Orion.AccountsWHERE AccountType IN ('1','2','3')--AND AccountID LIKE '%${SEARCH_STRING}%'ORDER BY AccountType, AccountID
Thanks for the reply. Yes, these are AD accounts, and those that have never logged in have '1/1/1900' in the LastLogin field. However, your SWQL query comes back with an error when used in the Custom Query resource.
What version of SolarWinds are you running?
Can screen capture the error your getting?
Here is what it looks like for me in edit mode:
For what its worth, I placed this code in my Orion (12.5) and it work without error....
Yes, we are using the same resource. My formatting looks the same. The error I get is "There was an error processing your request." I'm using 2019.4. Could it be the data format of the LastLogin field?
I am also on 2019.4. I would throw it in notepad++ and make sure no extra spaces/characters/or breaks got added in.
Ooops, jumped the gun a little. The query now works without error, but the result is showing ALL user accounts and their Last Login. I want ti to show ONLY those accounts that have never logged in (i.e. 1-1-1900). How do I get that?
I don't know if this will help, but hears a SWQL query - dashboard that I built to search for people. This report takes into account local accounts, local AD user accounts and AD user groups and shows then the last logged in. If a local user or local ADuser hasn't logged it'll give the standard 1/1/1900 date stamp like you see in the screen shot below. If an user in an AD Group hasn't logged in they simply won't show up on the report.
It's pretty binary.
SWQL Query
SELECT AccountID AS [User Account], LastLogin AS [Last Login], CASE WHEN AccountType='1' THEN 'Orion Account' WHEN AccountType='2' THEN 'Local AD account in Solarwinds' WHEN AccountType='3' THEN 'AD group' WHEN AccountType='4' THEN 'User account in a AD Group' End as [Account Type], GroupInfo AS [Group] FROM Orion.Accounts WHERE AccountType='4'OR AccountType='2'OR AccountType='1'--OR AccountType='3'Order BY AccountType ASC
SELECT
, CASE
FROM Orion.Accounts
OR AccountType='2'
OR AccountType='1'
SWQL Search Query
SELECT AccountID AS [User Account], LastLogin AS [Last Login], CASE WHEN AccountType='1' THEN 'Orion Account' WHEN AccountType='2' THEN 'Local AD account in Solarwinds' WHEN AccountType='3' THEN 'AD group' WHEN AccountType='4' THEN 'User account in a AD Group' End as [Account Type], GroupInfo AS [Group] FROM Orion.Accounts WHERE AccountID Like '%${SEARCH_STRING}%'OR GroupInfo Like '%${SEARCH_STRING}%'and AccountType<>'3'Order BY AccountType ASC
What I linked is a dashboard, you can click on 'last login' to sort.
If your using AD/SAML you would not see records until the user actually logs in. You would have to pull the AD group (powershell/cmd) and compare against who is missing from Orion DB.
