Hi:
I´m trying make a change in a map using Network Atlas, but I get this message:
Do you have an unreliable connection to the Orion server or is the DB losing connectivity?
Talking with my DBA, he told me that we have 42 connections from Orion server to the DB server.
This installation is a clone installation from a productions´s server (both application and DB clone). We desire create a development´s environment.
In our environment we have 2 pollers, and I didn´t stop first poller when I install second poller. This could be an issue ?
So you took your production install and cloned it for a lab install? I don't think that is going to work, can you not use an eval install for lab purposes?
The poller is an evaluate installattion, but DB is a production´s DB clone...
Poller? Do you mean you have an evaluation Orion install which you hooked up to a copy of your production DB? Either way, I think best path now is to log a support case
It´s only a test environment. Is there any problem doing that ?
I get the exact same error. I am running 9.5 sp4 but I never did any evaluation upgrades. This hasnt worked since my upgrade to 9.5.
