Hello,
I am wondering if there are available Network Atlas variables such as:
support.solarwinds.com/.../ProblemDetail.cfm
for the Voip Module/IP SLA Manager.
You will be able to use those properties with IP SLA operations in IP SLA Manager once it's released.
With IP SLA Manager you can use the following properties for IP SLA Operations
Unfortunately there currently is no way to get at the statistics of a particular operation.
VoIP 2.x or earlier are not supported by Network Atlas.
Feature request? Or is this coming with IPSLAM
Can I expect IP SLA statistic variables to be added sometime in the future? I would really like to be able to add packetloss and RTT to my architecture maps that already includes things like ${InBps} and ${InPercentUtil}
I think that you can see how this can be of use.
What else would you like to add so we can mark it down and log it to add
All of the results. So, jitter, MOS, packet loss, RTT, etc.
is it possible to have the variables that Congo listed above (jitter, mos, rtt) as a label on the map?
basically, I have a view made so i can see all of my SLAs on one map, and every time it refreshes, display the jitter, etc.
