Hi There,
Can someone explain to me, how to customize the "95th Percentile Traffic Rate -Last Month" report for one single device?
Ali
Since this is an advanced SQL Report, you will need to edit the SQL Query.
Open the Report in Report Writer. Click on The SQL Tab and add the following line just before the ORDER BY Statement:
WHERE Nodes.Caption='Node-Name'
Node-Name is the name of your single device.
ON (Interfaces.InterfaceID = RESULT_MAX.InterfaceID)---------------------WHERE Nodes.Caption='Node-Name'ORDER BY NodeName, Interface_Caption
Save the report under another name to keep the original report.
Thank You.
Is there a method for this to report for just a few interfaces on two devices?
Thx,
Dave
...Or a way to filter if I added a comment field?
Hi Dave,
If you add a custom property to the interfaces you want to report or if they begin with the same name, the results can be filtered too in the WHERE condition.
e.g.:
WHERE Interfaces.Report95thPercentile = 'true'
or it could be:
WHERE Interfaces.Caption LIKE "%FastEthernet%"
and you can combine multiple filters in the WHERE condition such as:
WHERE Nodes.Caption LIKE "%Server%" AND Interfaces.Caption LIKE "%FastEthernet%"
HTH,
Yann
I added a comment to only the interfaces I want to be in this report. Let's say it's "whatever". So it should look like this: WHERE Interfaces.Caption LIKE "%whatever%"?
Sorry to be such a pain...
I tried that string, and it didn't work.
In your first reply, you gave a string for a single 'Node-Name', Is there a way if I have two 'Node-Names'?
Thanks a ton for helping me!
Sure it should be possible:
WHERE Nodes.Caption='Node-Name-1' OR Nodes.Caption='Node-Name-2'
Weird...I attempted that, except I used AND...I assumed that's how that string would have went.
What do you think about the comment field? I tried that a couple different way and still no luck.
