Hi
Where could i get a copy of the ERD for Server Profiler?
thanks
carlos
Go to install/webapps/ROOT/bin
In the server.properities file, add the line showQueryInReportSource = true
Restart the webserver.
Let me know if that doesn't work.
See KB for more info:
http://knowledgebase.solarwinds.com/kb/questions/2392/Hiding+Profiler+report+queries+from+displaying+in+the+HTML+source+code.
There is not an ERD for Profiler, however, you can do a view source on any report you run and see the SQL statement for the report. You can use this as a base to build the query you want.
Brian
Hi Brian
Thanks for the response. I did as you suggested but don't see any SQL statements other than a commented out line pasted below with no other text.
I've attached the report. Could you kindly point to the SQL or where i might be going wrong?
Using IE 7 , Quick Reports -> Storage by Local Share -> Local Shares Assignment
//REPORT QUERY
[View:/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.09.07.52/local-Shares-Assignment.htm]
Note in recent versions - 4.12.2 and 4.12.3 I believe - the SQL was hidden by default. I ran the same report as above on 4.12.4, did a view source and the SQL was there:
//REPORT QUERY //SELECT a.DeviceId, a.DeviceHostName as Field_6069, name as Field_6070, basePath as Field_6071, Level as Field_6072 FROM ent_fa_local_paths_assignment b inner join devices a on a.deviceid = b.deviceid WHERE a.DeviceId IN (.....) AND selected = 1 ORDER BY Field_6069 ASC, Field_6070 ASC limit 0, 251
Where the "..." is a list of deviceid's in your system. You can remove that part of the query (ie "WHERE a.DeviceId IN (.....)") to get everything.
Yup- i'm running 4.12.3, is there a way to show the SQL ? or do i have to upgrade?
thanks again
-carlos
thank you Brian. I can see the sql now..
Great, let me know how else we can help.
