When i try and fetch the data from SWQL studio for the query
" SELECT TOP 1 NodeID, ObjectSubType, IPAddress FROM Orion.Nodes " , i get the result instantaneously.
However when i try to do the same from the query below , it takes around 5-6 mins.
https://<SolarwindsServerIP>:17778/Solarwinds/InformationService/v3/Json/Query?query=SELECT%20TOP%201%20NodeID,%20ObjectSubType,%20IPAddress%20FROM%20Orion.Nodes%20
What am i doing wrong ?
There doesn't appear to be anything wrong with the way you are structuring the URL. I tried it and got a sub-second response. This is running in Chrome on my Windows 10 laptop against a VM running in the corporate intranet. You might want to look at the Network tab in the Chrome DevTools (or the browser tools of your choice) to see if it reveals any clues. You should also check the SolarWinds Information Service (SWIS) logs. There is information about that here. Do you encounter any problems browsing the web pages of Orion from the same location that you're trying to run this query?
The Orion web pages don not have any issues loading or displaying data. Here below is a curl output,
J:\>curl -k -v -u testuser:testuser https://<SOLARWINDS_IP>:17778/Solarwinds/InformationService/v3/Json/Query?query=SELECT TOP 1 NodeID, ObjectSubType, IPAddress FROM Orion.Nodes * Trying <SOLARWINDS_IP>...* TCP_NODELAY set* Connected to <SOLARWINDS_IP> port 17778 (#0)* schannel: SSL/TLS connection with <SOLARWINDS_IP> port 17778 (step 1/3)* schannel: disabled server certificate revocation checks* schannel: verifyhost setting prevents Schannel from comparing the supplied target name with the subject names in server certificates.* schannel: sending initial handshake data: sending 178 bytes...* schannel: sent initial handshake data: sent 178 bytes* schannel: SSL/TLS connection with solarwinds.fcstone.com port 17778 (step 2/3)* schannel: encrypted data got 913* schannel: encrypted data buffer: offset 913 length 4096* schannel: sending next handshake data: sending 358 bytes...* schannel: SSL/TLS connection with <SOLARWINDS_IP> port 17778 (step 2/3)* schannel: encrypted data got 91* schannel: encrypted data buffer: offset 91 length 4096* schannel: SSL/TLS handshake complete* schannel: SSL/TLS connection with <SOLARWINDS_IP> port 17778 (step 3/3)* schannel: stored credential handle in session cache* Server auth using Basic with user 'testuser'> GET /Solarwinds/InformationService/v3/Json/Query?query=SELECT%20TOP%201%20NodeID,%20ObjectSubType,%20IPAddress%20FROM%20Orion.Nodes%20 HTTP/1.1> Host: <SOLARWINDS_IP>:17778> Authorization: Basic dGVzdHVzZXI6dGVzdHVzZXI=> User-Agent: curl/7.55.1> Accept: */*>* schannel: client wants to read 102400 bytes* schannel: encdata_buffer resized 103424* schannel: encrypted data buffer: offset 0 length 103424* schannel: Curl_read_plain returned CURLE_RECV_ERROR* schannel: encrypted data buffer: offset 0 length 103424* schannel: encrypted data buffer: offset 0 length 103424* schannel: decrypted data buffer: offset 0 length 4096* schannel: schannel_recv cleanup* Closing connection 0* schannel: shutting down SSL/TLS connection with <SOLARWINDS_IP> port 17778* Send failure: Connection was reset* schannel: failed to send close msg: Failed sending data to the peer (bytes written: -1)* schannel: clear security context handlecurl: (56) Send failure: Connection was reset
If i run the same command 2-3 times continuously , i get a proper output on the 3rd attempt.
It looks like things are fine down to this...
Send failure: Connection was resetschannel: failed to send close msg: Failed sending data to the peer (bytes written: -1)
I wonder if your network connection to the Orion server is spotty for some reason. When attempting this from a browser, this works consistently, but takes a long time? What happens when you run this on the Orion server itself?
For reference, here is what the curl invocation looks like for me, with some masking for server names, passwords, etc:
C:\WINDOWS\system32>curl -k -v -u <User>:<Password> https://<Server>:17778/Solarwinds/InformationService/v3/Json/Query?query=SELECT TOP 1 NodeID, ObjectSubType, IPAddress FROM Orion.Nodes * Trying <IP Address>...* TCP_NODELAY set* Connected to <Server> (<IP Address>) port 17778 (#0)* schannel: SSL/TLS connection with <Server> port 17778 (step 1/3)* schannel: disabled server certificate revocation checks* schannel: verifyhost setting prevents Schannel from comparing the supplied target name with the subject names in server certificates.* schannel: sending initial handshake data: sending 181 bytes...* schannel: sent initial handshake data: sent 181 bytes* schannel: SSL/TLS connection with <Server> port 17778 (step 2/3)* schannel: failed to receive handshake, need more data* schannel: SSL/TLS connection with <Server> port 17778 (step 2/3)* schannel: encrypted data got 1213* schannel: encrypted data buffer: offset 1213 length 4096* schannel: sending next handshake data: sending 93 bytes...* schannel: SSL/TLS connection with <Server> port 17778 (step 2/3)* schannel: encrypted data got 51* schannel: encrypted data buffer: offset 51 length 4096* schannel: SSL/TLS handshake complete* schannel: SSL/TLS connection with <Server> port 17778 (step 3/3)* schannel: stored credential handle in session cache* Server auth using Basic with user '<User>'> GET /Solarwinds/InformationService/v3/Json/Query?query=SELECT%20TOP%201%20NodeID,%20ObjectSubType,%20IPAddress%20FROM%20Orion.Nodes%20 HTTP/1.1> Host: <Server>:17778> Authorization: Basic <Auth Token>> User-Agent: curl/7.55.1> Accept: */*>* schannel: client wants to read 102400 bytes* schannel: encdata_buffer resized 103424* schannel: encrypted data buffer: offset 0 length 103424* schannel: encrypted data got 246* schannel: encrypted data buffer: offset 246 length 103424* schannel: decrypted data length: 217* schannel: decrypted data added: 217* schannel: decrypted data cached: offset 217 length 102400* schannel: encrypted data buffer: offset 0 length 103424* schannel: decrypted data buffer: offset 217 length 102400* schannel: schannel_recv cleanup* schannel: decrypted data returned 217* schannel: decrypted data buffer: offset 0 length 102400< HTTP/1.1 200 OK< Content-Length: 78< Content-Type: application/json< Server: Microsoft-HTTPAPI/2.0< Date: Wed, 29 Apr 2020 19:30:23 GMT<{"results":[{"NodeID":1,"ObjectSubType":"Agent","IPAddress":"<IP Address>"}]}* Connection #0 to host <Server> left intact
I get the output you shared only after 3-4 continuous attempts on curl.
On a browser i get a certificate warning first, followed by "This site cant be reached. Connection was reset" .
On refreshing the browser 2-3 times , it prompts for credentials. After entering the credentials, i get the desired output after 2-3 minutes.
This happens from within the solarwinds server as well as outside the server.
I was wondering if the below underlined configuration setting has something to do with the results.
C:\Windows\system32>netsh http show sslcert
SSL Certificate bindings:-------------------------
IP:port : 0.0.0.0:17778Certificate Hash : <VALUE>Application ID : <VALUE>Certificate Store Name : (null)Verify Client Certificate Revocation : EnabledVerify Revocation Using Cached Client Certificate Only : EnabledUsage Check : EnabledRevocation Freshness Time : 0URL Retrieval Timeout : 0Ctl Identifier : (null)Ctl Store Name : (null)DS Mapper Usage : DisabledNegotiate Client Certificate : DisabledReject Connections : DisabledDisable HTTP2 : Not Set
IP:port : 0.0.0.0:443Certificate Hash : <VALUE>Application ID : <VALUE>Certificate Store Name : MyVerify Client Certificate Revocation : EnabledVerify Revocation Using Cached Client Certificate Only : DisabledUsage Check : EnabledRevocation Freshness Time : 0URL Retrieval Timeout : 0Ctl Identifier : (null)Ctl Store Name : (null)DS Mapper Usage : DisabledNegotiate Client Certificate : DisabledReject Connections : DisabledDisable HTTP2 : Not Set
To provide context on this question, see also https://thwack.solarwinds.com/t5/Discussions/Issues-with-the-SWIS-API/m-p/587341.
