Is there a way to create alerts for netflow traffic? Basically, I would like to have an elert emailed out if a flow exceeds xMB of data over x number of minutes.
Jon
That particular alert does not exist today but we have one built in 10.1 that will send you top talkers when an interface reches a threshold you set.
Hi Andy,
I'm sure that I am looking right at this, but I don't see this alert. Where can I find it? I am running NPM 10.1.1
Use the Top talkers alert shown below.
Thanks Andy,
Any idea when more netflow alerts will be made available?
jon,
Are there specific alerts you would like to see? We are always looking to make life easier on our users.
Also, if you would like more detail on the Top Talker alerts, I recommend refering to the NTA Admin Guide - specifically, Chapter 7.
www.solarwinds.com/.../NetFlowAdministratorGuide.pdf
Mav
Hi Mav,
I'll definitely check out the NTA Admin Guide. As far as alerts go, we have run into an issue where one of our 1gig links gets saturated and then pretty much does a DOS on that segment. We were hoping that we could setup an alert that if a flow grew to x mbps on a specified link, it would alert us. That way we could determine what was causing it as it was occurring instead of doing this after the fact.
If the DOS attacks are saturating the link, the existing NetFlow alerts will work as they trigger off of a bandwidth threshold.
And this is now available in General Release as NTA version 4.5!
You can check out the Release Notes, download the new release on the Customer Portal, and get all the help they need with the upgrade at the Success Center.
joer
