SNMP Polling backs up and then the website slows down and we don't get any new data on any of our devices in solarwinds. any ideas what is happening?
That's a pretty general symptom. Can you provide some specifics?
Device count, element count, SQL server hardware, Orion software revs?
Orion Network Performance Monitor Version 9.5.0NetPerfMon Engine Network Node Elements 589Interface Elements 10432Volume Elements 940Date Time 9/14/2009 4:42:36 PMPaused FalseMax Outstanding Polls 900Status Pollers ICMP Status Polling Index 11961 out of 11961SNMP Status Polling Index 10310 out of 11961ICMP Polls per second 2.5SNMP Polls per second 231Max Status Polls Per Second 231Packet Queues DNS Outstanding 0ICMP Outstanding 191SNMP Outstanding 704Statistics Pollers ICMP Statistic Polling Index 22708 out of 22708SNMP Statistic Polling Index 1471 out of 22708ICMP Polls per second 93SNMP Polls per second 101Max Statistic Polls Per Second 101
assuming this is on one poller, you have way to many polls for one polling engine.
SW recommends under 8000 per polling engine. I have about 18000 polls across 3 machines and it works like a champ.
I think I saw in 9.5 that the poll tuning is done automatically, but you might want to check that as well.
I'm having a problem that I only have about 5k elements on a polling engine, but it can't keep up consistently. IT's set at the max of 300 polls p and I had to turn Status polling to max and I am still dropping
what version(s) are you running? I've had issues as well and opened a few tickets and have gotten fixed. let me know.
I'm running the new 9.5.1
open a ticket and have them check to see if it may be along the same lines as my ticket...
case#140780
