I am trying to monitor task scheduler jobs on windows server. How can I do that. I tried using tempalate windows task scheduled tasks but somehow it doesnot lead me to the application and component monitor. I am using SAM 6.2.2.
Please asssist.
If you have SAM alone then you can do this by applying the Application Monitor templete to the node your after.
Other way is if you have NPM as well, select the node and list resources. Windows Task monitoring will be there - uses 5 SAM license components per server monitored.
Provided the node is managed via WMI or through the Agent, monitoring Windows Scheduled Tasks appears as an option for monitoring under "List Resources" as outlined in the following blog post.
Server & Application Monitor 6.1 - New Feature Overview and Beta Sign-Up
Thank you so much!! It was just what I needed!
What if for a server I am not able to get Windows schedule option in list resources.
Happening with SAM 6.6.
Is there any alternative or solution to this?
https://thwack.solarwinds.com/people/richa%20arya wrote:What if for a server I am not able to get Windows schedule option in list resources.Happening with SAM 6.6.Is there any alternative or solution to this?
Ensure the node is managed via WMI or the Orion Agent. ICMP and SNMP Managed nodes are not supported by SAM's Windows Scheduled Task Monitor.
It is being monitored via agent.
Are there any Windows Scheduled Tasks configured on the machine? If so, it should appear as an option when you click 'List Resources'.
Yes windows tasks are being confgured on teh machine.
But still windows scheduled task option is not listed out in list resources.
Are those Windows Scheduled Tasks in the root of the hierarchy, or are they nested in folders?
The task that needs to be monitored are in the nested folder.
In that case, how do we monitor the status of all the jobs that are residing in sub folders?
Is there any update on how to monitor tasks in sub folders?
